Home > Forums > Software User Forums > SU2
Error in shape optimization SU2 v3.2.8
Old   January 25, 2016, 13:47
Unhappy Error in shape optimization SU2 v3.2.8
Milano
Fedey90 is on a distinguished road
Hello to everyone!
I'm in trouble with the shape_optimization.py. I'm following the instructions of the tutorial for optimization (https://github.com/su2code/SU2/wiki/Constrained-Optimal-Shape-Design-of-a-Fixed-Wing) and computing in SU2 v3.2.8 with the Test Cases of the same version.
This is the error:
RuntimeError : Path = /home/federica/TestCases/optimization_euler/steady_oneram6/DESIGNS/DNS_001/DIRECT/,
Command = mpirun -n 1 usr/local/bin/SU2_CFD config_CFD.cfg
SU2 process returned error '255'
[proxy:0:0@federica-VirtualBox] HYDU_create_process (./utils/launch/launch.c:75): execvp error on file usr/local/bin/SU2_CFD (No such file or directory)
I donno why, coz I find the file in the directory usr/local/bin and it's an executable.
When I try to run the command with -n 0 this is the error:
Command = usr/local/bin/SU2_CFD config_CFD.cfg
SU2 process returned error '127'
/bin/sh: 1: usr/local/bin/SU2_CFD: not found
How can I fix it?
Thank you for your help
Fedey90 is offline   Reply With Quote
Old   January 26, 2016, 05:15
Tim Albring
talbring is on a distinguished road
Hi Fedey90,
make sure that you have set the environment variables correctly like it is described here:
https://github.com/su2code/SU2/wiki/...ment-variables
Furthermore consider to update to the new version 4.1 if you need any further help.
talbring is offline   Reply With Quote
Old   January 31, 2016, 11:12
Milano
Good morning. I just see that I set all the variables during the installation. The same error occurs. So I'll try to install the new version. I'll inform you if it will be done
Old   January 31, 2016, 17:27
Milano
Here another problem: I downloaded the new Test cases.git, but in the steady_one ram folder (in optimization_euler) there isn't any .cfg file. How can I solve it? Remember: I'm following your tutorial
Old   February 7, 2016, 11:34
Francisco Palacios
fpalacios is on a distinguished road
The config files are in the SU2.git. The folder is called TestCases
Thanks for using SU2,
Best
Francisco
fpalacios is offline   Reply With Quote
optimization, su2, su2 oneram6
SU2 Shape optimization questions AdriC SU2 Shape Design 6 January 27, 2016 05:25
Question about SU2 optimization YoniHe SU2 Shape Design 3 January 15, 2016 01:31
SU2 shape optimization initialization method? gina07 SU2 Shape Design 1 May 2, 2015 17:40
Airfoil Shape Optimization using gradient based methods jaiswal Main CFD Forum 1 April 10, 2014 12:22
Testcase for shape optimization using RANS simualtion diwakaranant SU2 Shape Design 1 April 18, 2013 14:27
