Home > Forums > Software User Forums > SU2
SU2 LM Transition Model (v4.1.0 cardinal release)
Old   January 21, 2016, 16:49
Exclamation SU2 LM Transition Model (v4.1.0 cardinal release)
C
whizkid is on a distinguished road
Hello all SU2 users,
I wonder if anyone has solved ERCOFTAC T3 zero pressure gradient transitional flow on flat plate test cases before.
I try to validate these test cases, but seem to have problems with the KIND_TRANS_MODEL = LM coupled with KIND_TURB_MODEL = SA. Maybe my input file is not proper, but every single time i try, i got the divergence error (tons of lines of output is printed on the command window, related to the transition model parameters and i think that is for debugging purpose?)
If anyone has done it before, would you please share the configuration file with me? As soon as I make sure everything runs smooth and the validations are completed, I will be working on implementing my own promising transition model (AIAA 2013-2531).
Also, it would be great if a tutorial document for at least maybe T3A case is released officially (I know laminar flow and fully turbulent flow over flat plate tutorials are up there, but obviously they do not have the transition model activated).
Thanks in advance!
Best,
whizkid is offline   Reply With Quote
Old   January 26, 2016, 05:46
Tim Albring
talbring is on a distinguished road
Hi whizkid,
the transition model is still under development and not working yet.
talbring is offline   Reply With Quote
ercoftac, su2 documentation, transition model, transitional flow
New release of SU2 V3.2.1 fpalacios SU2 News & Announcements 0 September 9, 2014 02:17
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 03:40
CFX transition model issue with VATT PLD CFX 5 April 22, 2014 06:21
Viscosity ratio in gamma-theta transition model based on k-w sst turb model Qiaol618 Main CFD Forum 8 June 9, 2012 07:43
Missing Information in SST Transition Model Formulation Josh CFX 2 September 14, 2010 12:49
