Home > Forums > Software User Forums > SU2
How to get su2 meshes from NASA's plot3D/cgns grids
Old   December 7, 2015, 21:52
Default How to get su2 meshes from NASA's plot3D/cgns grids
OVS
Oliver V
OVS is on a distinguished road
I'm kinda new with CFD so please don't be too harsh on me. I have read a considerable amount of information on it and on SU2 though but I lack some practice.
For a student homework, I'm doing some simple validations concerning the SA turbulence model on SU2. I'm trying to reproduce NASA's NACA0012 airfoil validation case.
http://turbmodels.larc.nasa.gov/naca0012_val.html
I was thinking on doing my own grids on icem but then I saw they released readily available grids. The problem though is that
(1) the 2D grids are in a special format which I've never seen before and the 3D cgns grids are in the "wrong" coordinate system (plus they are on 3D).
(2) How do I add markers to these grids to identify the farfield and the airfoil? I tried importing a mesh into ICEM CFD but apparently you can only mark points...
Thanks for your help!
Oliver
OVS is offline   Reply With Quote
Old   February 19, 2016, 15:13
xin
guxin7005 is on a distinguished road
https://confluence.cornell.edu/displ...arning+Modules
Here you can find a lot example about using those mesh to simulate.both 2d cases and 3d cases.
guxin7005 is offline   Reply With Quote
Old   February 23, 2016, 01:13
Eduardo Molina
EMolina is on a distinguished road
Did you tried the naca0012 grids provided by the SU2 team in github? They should perform pretty well...
EMolina is offline   Reply With Quote
Old   February 23, 2016, 10:30
xin
That is awesome!!
by the way, do you know where can I find 3d naca0012 with wingtip mesh ?
Old   February 29, 2016, 13:07
OVS
Oliver V
Yes I did. I found they had done similar validation cases.
I used the 897x257 meshes. Although I find their .cfg files have a VERY STRICT convergence criteria which increases the time calculation a lot. I based my .cfg on the one found in the source files (TestCases/rans/naca0012/turb_NACA0012_sa.cfg)
Their convergence criteria is Residual with 10 orders of magnitude reduction (or a 1e-12 minimum value) which is A LOT, asking around I was told industry would use 6 orders of magnitud at max. Calculation ran for ages before I had to stop it. I found out results weren't as good unless this restrictive convergence was used...
Using the TestCase, the convergence comes after 186636 iterations (95.5h on an 8 core machine)
CL and CD values for test cases were close enough at low angles of attack, but when I moved to 15 it didn't really fit all that well until harsh convergence criteria were used (CL = 1.55649 CD = 0.02237 ). Compared to the range proposed by NASA's study it is very close, even in range for the CL (1.5446 - 1.5642), but a tad bit high on the CD (0.02073 - 0.02159). Cd is more than 3% higher at 15 degrees than the maximum Cd given by NASA.
My guess is that it may have something to do with the Cf calculation near the walls...
mesh 2d
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 45 October 16, 2024 18:26
[Other] plot3DToFoam: converting backstep grids from NASA's website samiam1000 OpenFOAM Meshing & Mesh Conversion 2 January 2, 2015 17:51
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 15:55
EnGrid makes SU2 grids Speng SU2 4 October 31, 2013 16:59
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
