Home > Forums > Software User Forums > SU2
Config option deprecation
Old   December 5, 2015, 19:17
Default Config option deprecation
Jean-Philippe Caron
Fallen Ghost is on a distinguished road
Like erams in an earlier post, I installed SU2 using the Windows binaries, and it works as it should.
Now, trying to do the quickstart tutorial as well, I found that there is at least a version on github that is using deprecated config options. (ie: su2code/documentation/quickstart/[])
I appreciate that it is particularly hard to maintain backwards compatibility when the program is still in development. Apart from reading and comparing the config_options.cfg file every new version, how often do these instructions change?
I'm sure you have thought of that, and was wondering if there is a resource/file/thread that keeps track of that?
Fallen Ghost is offline   Reply With Quote
Old   February 23, 2016, 13:12
hlk
Heather Kline
hlk is on a distinguished road
Please use the quickstart tutorial in the su2code/SU2/ repository instead, that one is up to date.
For tracking config file option changes, the config_template.cfg file in the SU2 repository is usually the best way - we try not to change them too frequently, and have an error message that will help users identify which options need to be removed or modified.
hlk is offline   Reply With Quote
Old   February 23, 2016, 19:12
Jean-Philippe Caron
Ah very well, I'll keep that in mind. Thanks for the help!
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
