SU2_DEF : There are N elments with negative volume |
November 29, 2015, 00:38 |
Jason Shih
Rep Power: 11 |
Hi, guys.
I use SU2 for M6 optimization. The grid I use is download from (http://www.grc.nasa.gov/WWW/wind/val...1/m6wing.x.fmt). The FFD degree is (4,4,1) . I set the DV_VALUE to 1e-5 for one of the control point and set the others to zero,when I use SU2_DEF for grid deformation, it shows that there are 500 elements with negative volume . The mesh is good when I use SU2_CFD for direct computation. The FFD box is attached below, the green line is the deformed box. So how should I fix this problem? Thanks! Jason Shih Last edited by dasssj; November 29, 2015 at 04:30. Reason: Wrong type |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] negative sector volume | adam2008 | ANSYS Meshing & Geometry | 0 | August 9, 2014 00:24 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
remeshing due to negative volume error | Doginal | CFX | 1 | August 21, 2011 21:50 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
