Unexpected increase in computation time for SU2_DOT - SU3.2.8 |
November 18, 2015, 11:58 |
Bram Timmer
Rep Power: 11 |
Dear all,
For my master thesis I'm running an optimization on a conventional wing using multiple FFD boxes: 1: FFD box enveloping the entire wing, used to change the sweep angle. 2: FFD box enveloping the shock wave area on the upper surface of the inboard wing. 3: FFD box enveloping the shock wave area on the lower surface of the outboard wing. Last night I noticed some discontinuities between the inboard and outboard boxes (at their junction) and decided to change from having two separate boxes to have a single box enveloping the area of the upper surface that I am interested in (also for other reasons). See pictures below for clarity: The old two boxes (deg_i = 9, deg_j = 19, deg_k = 1, for both): The new box (deg_i = 19, deg_j = 19, deg_k = 1): Before the change, running SU2_DOT for 400 variables spread over the two boxes would take 400 seconds (possibly less). After the change, running SU2_DOT for 210 variables takes at least 2100 seconds, if not more.. it's a ridiculous increase of computation time for no apparent reason (you would expect a decrease considering the change in number of variables!). Does anybody know what causes this increase in computation time and possibly a way to avoid it? Your help will be greatly appreciated! Regards, BramT Last edited by BramT; November 18, 2015 at 11:59. Reason: Images were not visible |
computation time, su2_dot, su3.2.8 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
