Home > Forums > Software User Forums > SU2
Any suggestion about improving the convergence speed of SU2?
Old   October 29, 2015, 05:14
Default Any suggestion about improving the convergence speed of SU2?
Jason Shih
dasssj is on a distinguished road
I'm using SU2(3.2.7) for CFD research. In my case(RAE2822, C grid, Ma = 0.729, Re = 6.5E6, AoA = 2.31),the solver can not converge in 5000 steps. It takes so much time so I think maybe there are some options in the configuration file have not been properly set.
My cfg file and the mesh file are attached bellow. Can anybody tell me what should I do so that the solver will converge a little faster?
Thank you!
dasssj is offline   Reply With Quote
Old   October 30, 2015, 15:26
Santiago Padron
Santiago Padron is on a distinguished road
After looking at your config file, I would suggest you turn on multigrid to greatly reduce the number of iterations.
You can change it from MGLEVEL= 0 to MGLEVEL= 2 or 3.
Santiago Padron is offline   Reply With Quote
Old   October 31, 2015, 02:51
Jason Shih
Hi, Santiago, thank you for your reply.
I do as you said, but this time it divergences when I set MGLEVEL= 2 or 3. Is that any other option I have to change?
Old   October 31, 2015, 10:13
Francisco Palacios
fpalacios is on a distinguished road
I agree with Santiago, if the MG works then it is one of the best methods. You are running a C grid and the MG should help. Could you please try with
MGLEVEL= 2
MGCYCLE= V_CYCLE
MG_PRE_SMOOTH= ( 1, 1, 1, 1 )
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
MG_DAMP_RESTRICTION= 0.75
MG_DAMP_PROLONGATION= 0.75
On the other hand, If you are going to run RANS I would use
CONV_NUM_METHOD_FLOW= ROE-2ND_ORDER
In fact, looking at your config file, I have noticed that you are running an old version of SU2. Could you please try with the v4.0.1? In fact, in that version you will have a new option called adaptive CFL. And you can try something like:
CFL_ADAPT= YES
CFL_ADAPT_PARAM= ( 1.5, 0.5, 1.0, 25.0 )
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   November 5, 2015, 05:06
Jason Shih
Thank you for your reply, Francisco.
I falied to compile v4.0.1 on windows 7,so I still use v3.2.7. I change the options you suggested except CFL_ADAPT and CFL_ADAPT_PARAM, but it seems that the sover still converge slowly.
I'm not really understand what do these options mean:
Is there any document about these options?
Thank you very much!
Jason
Old   November 5, 2015, 05:08
Jason Shih
Originally Posted by fpalacios View Post
MGLEVEL= 2
MGCYCLE= V_CYCLE
CFL_ADAPT= YES
Best,
Francisco
I falied to compile v4.0.1 on windows 7,so I still use v3.2.7. I change the options you suggest except CFL_ADAPT and CFL_ADAPT_PARAM, but it seems that the sover still converge slowly.
Jason
convergence problems, su2
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
Convergence speed in free surface simulations Chebeba CFX 13 July 23, 2009 14:08
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 15:20
speed up convergence for drag Aymeric CFX 1 March 8, 2006 19:56
Convergence Speed Maciej Matyka Main CFD Forum 1 June 12, 2003 13:20
