Home > Forums > Software User Forums > SU2
Not defined orientation change while running SU2_CFD
Old   October 26, 2015, 10:19
Default Not defined orientation change while running SU2_CFD
Matt Dawson
mdawson25 is on a distinguished road
I am currently analyzing the flow over a cylinder using a geometry and mesh created in Gmsh. It is a cubic volume, four faces serving as farfield boundary conditions with the two that intersect the cylinder being symmetry. The surface of the cylinder is marked using the Navier-Stokes (no-slip) constant heat flux marker.
While running SU2, I see the following appear during the initial stages:
---Geometry Preprocessing---
Setting point connectivity.
Renumbering points (Reverse Cuthill McKee Ordering).
Recomputing point connectivity.
Setting element connectivity.
Checking the numerical grid orientation.
(this continues for several more lines)
Once the Residual Evolution Summary appears I see non-physical points in the solution and non-physical states in the upwind reconstruction. This persists until SU2 tries to create an output file and then SU2 crashes.
I believe this "Not defined orientation change" error is leading to the other errors but even after some googling I haven't located a solution. Is there something I need to set in my SU2 config file or is this an issue with the mesh I have created in Gmsh then converted to an .SU2 file?
Best Regards,
Matt
mdawson25 is offline   Reply With Quote
Old   October 29, 2015, 02:32
Francisco Palacios
fpalacios is on a distinguished road
Thanks for using SU2,
Unfortunately I have found similar problems in the past with gmesh. Could you please try to generate a grid with only tetrahedra
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   October 29, 2015, 14:22
Matt Dawson
Francisco,
I have gone back and edited my gmesh file to output only tetrahedral elements. After running SU2_CFD, I no longer get the orientation errors or the non-physical locations in the solution! In turn, the solution file is able to be output and no crash occurs.
Thanks for the help,
Matt
Old   May 10, 2017, 21:35
Alberto Pizarro
AlbertoPi is on a distinguished road
Best,
Francisco
Hi
I'm meshing a 3D wing and I have the same error.
I have a prismatic boundary layer with 4 million elements. I have 7 million elements in total and with my RAM (32Gb) I can not have more than 8 million elements to run SU2_CFD.
If I do not use "Recombine" in the "Extrude" of the boundary layer to get only tetrahedra, I have too many elements.
Do you know any other solution for this?
Thank you.
AlbertoPi is offline   Reply With Quote
Old   May 11, 2017, 10:52
Alberto Pizarro
Originally Posted by AlbertoPi View Post
Hi
Thank you.
Finally I found the way to do it. Getting prims and tetrahedras but no pyramids at final mesh. It looks like the pyramids were the problem.
Now the message "Not defined orientation change" doesn't appear, but non-physical points still appering.
Regards.
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 14 February 12, 2017 14:44
UDF link fortran source yorelchr Fluent UDF and Scheme Programming 0 February 7, 2013 04:44
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 05:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 06:06
