October 19, 2015, 12:42 |
List of available SU2 turbulence models?
Klaus
Rep Power: 22 |
is there a list of available SU2 turbulence models? Is a transition flow turbulence model laminar-turbulent available? (Test case or tutorial also?) Klaus |
January 8, 2016, 21:22 |
#2 | |
Heather Kline
Rep Power: 14 |
The list of turbulence models available can be found in config_template.cfg Unfortunately, although some people are working on the transition capability, it is not currently available. |
Multiphase Turbulence Models | im_lenny | OpenFOAM Running, Solving & CFD | 8 | January 31, 2019 11:37 |
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 10:14 |
Read inside a class | tonyuprm | OpenFOAM | 12 | July 14, 2010 03:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
