September 16, 2015, 03:14 |
B.C. in SU2 *cfg. file from Pointwise
Corrado
Rep Power: 17 |
Hello everyone,
from tutorials and videos it'not clear to me how boundary conditions, in a Pointwise mesh file, are exported SU2. In particular the relation between b.c. in Pointwise and "markers" in SU2 *cfg.file. Are the b.c. names defined in Pointwise to be the same of markers ? That is, "inlet" or "pressure outlet " or "wall" in Pointwise are automatically recognized by SU2 , once I have defined "Marker_INLET=inlet" , "Marker_WALL = wall" ans so on... ? Thank you in advance cpinz |
September 16, 2015, 12:33 |
#2 | |
Mandar Kulkarni
Rep Power: 13 |
You can look at more information here. -Mandar |
September 18, 2015, 05:32 |
Corrado
Rep Power: 17 |
Hi kmandar,
you are referring to the mesh file, while I'm referring to *.cfg file where I find the section as the following (taken from SU2 tutorials ): % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_HEATFLUX= ( airfoil, 0.0 ) % % Farfield boundary marker(s) (NONE = no marker) MARKER_FAR= ( farfield ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( airfoil ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( airfoil ) In Pointwise I create boundary condition assigning a give "type" b.c. to different part of domain, each one with its name , e.g: name type wing wall inlet inlet outlet outlet upper domain symmetry lower symmetry After that I export the mesh in SU2. In order to run the analysis, I have to fill up the SU2 *.cfg file with all data, and among them those described above relative to b.c. section. Now my question: how have I to modify ( if I have to do it..) such section in order to match Pointwise and SU2 data correctly ? Thank you in advance for any advice. Cpinz |
September 18, 2015, 09:48 |
Mandar Kulkarni
Rep Power: 13 |
Hi Cpinz,
I am guessing that the "name" of the boundary you specify in Pointwise should be the marker tag. To make sure it is so, you will have to check the .su2 file. After that it's simple- you specify the corresponding markers tags in the configuration file. SU2 will identify the boundary elements / nodes based on this marker tag and apply the corresponding boundary condition. The options for different boundary conditions are shown in the template file. Hope this helps, Mandar |
September 18, 2015, 11:24 |
Corrado
Rep Power: 17 |
KMandar,
I will check it. Thank you cpinz |
September 23, 2015, 03:41 |
Corrado
Rep Power: 17 |
Hi kmandar,
your advice work. I have now another problem: my domain boundaries are composed by one farfield and two walls (represented by a main wing and a flap) . At first attempt I tried to declare the b.c. as: % MARKER_HEATFLUX= ( main,0 ) MARKER_HEATFLUX= ( flap,0 ) MARKER_far= ( farfield ) but I incurred in an error ( " marker_heatflux option declared twice") then I tried wth: MARKER_HEATFLUX= ( main,0 ) MARKER_isothermal= ( flap,298 ) MARKER_far= ( farfield ) and it seemd could work, even if I'm not sure it's the correct way ( no errors but other adjustment to make in the config. file ). My question: which marker have I to use in the case of many "wall" boundaries ( more than two)? I didn't find any tutorial dealing with such option.... Thank you in advance |
September 26, 2015, 16:22 |
Mandar Kulkarni
Rep Power: 13 |
Hi cpinz,
To clarify, I understand that you have two different physical boundaries (wing and flap) to which same boundary condition (heatflux) has to be applied. I would try making the same marker tags for both the boundaries in the .SU2 file, and then specify the boundary condition just once in the config file. For example, go the SU2 file and change the marker tags for both the boundaries as 'heatflux' and then in the config file, specify MARKER_HEATFLUX= ( heatflux ) Hope this helps, Mandar |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
