September 7, 2015, 04:48 |
Dynamic remeshing
Hello all,
I am trying to compute moving bodies simulations within SU2. The dynamic moving body works fine but I end up with higly stretched elements for large motions. Is there a way to do remeshing with SU2? Thank you. |
September 15, 2015, 17:22 |
R. Sanchez
Rep Power: 12 |
as of now there is not a way to do remeshing implemented in SU2. The mesh update is done using a linear-elasticity approach, which may be controlled by using the following parameters: DEFORM_LINEAR_ITER= 500 -> Number of smoothing iterations DEFORM_NONLINEAR_ITER= 1 -> Number of deformation increments Hope this helps, and thanks for your interest in SU2. |
September 28, 2015, 04:20 |
Hello rsanfer,
Thank you for your reply. Unfortunately, the linear-elasticity ends up with very streched meshes on my cases. I thought that combining the unsteady mesh adaptation with dynamic moving body would be a solution to solve this kind of problems, but it seems that no one has implemented/tried it yet. Thanks again. |
dynamic mesh, moving body |
Dynamic remeshing query | siw | FLUENT | 1 | September 30, 2009 05:12 |
Which meshes can be used for dynamic remeshing? | siw | FLUENT | 0 | August 20, 2009 10:19 |
dynamic remeshing of interface | john | FLUENT | 0 | November 2, 2006 01:47 |
Dynamic mesh (local remeshing) I'm stuck | Mike | FLUENT | 2 | February 26, 2006 15:00 |
Dynamic Grid Remeshing causing Divergence? | Andrew Wick | FLUENT | 0 | January 23, 2006 19:39 |
