Home > Forums > Software User Forums > SU2
no fea restart file error in fsi
Old   July 20, 2015, 04:00
Default no fea restart file error in fsi
varghese mathew
varghese9 is on a distinguished road
i am trying to run the restart option for su2 fsi case of agard wing but it shows following error as stated below
----------------- Integration and Numerics Preprocessing ----------------
Integration Preprocessing.
Numerics Preprocessing.
Setting dynamic mesh structure.
Area projection in the z-plane = 0.
Initialize Stiffness structure (Linear Elasticity).
Initialize Jacobian structure (Linear Elasticity).
There is no fea restart file!!
how do i get restart file for fea .i have only flow restart file
kindly guide me through
varghese9 is offline   Reply With Quote
Old   August 20, 2015, 23:01
hlk
Heather Kline
hlk is on a distinguished road
It is wonderful that you are interested in the fsi capability, I have seen many of your posts.
Due to the structure of github and the open source, you are able to see branches and parts of the code that are still under development, and not ready for wide use. Please refer to the tutorials, regression tests (also visible on github), and note that anything outside of the master branch is most likely under active development. Unfortunately, SU2_FSI is not yet ready for use.
Please be patient as we continue development on the FSI capability. If you need a particular capability urgently, please feel free to fork the code and make the changes necessary for your work.
hlk is offline   Reply With Quote
Old   August 21, 2015, 02:49
Talking
varghese mathew
the reason why i asked this sir is just to make sure that whether i have done anything wrong from my side.as there can be good chances as a fresher i can commit some errors wile setting up the parameters .
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
