Home > Forums > Software User Forums > SU2
Terminate called after throwing an instance of 'int'
Old   July 12, 2015, 04:26
Default Terminate called after throwing an instance of 'int'
Sparsh
Sparsh is on a distinguished road
I am getting this error, Terminate called after throwing an instance of 'int', in solving NSE for a 3D wing using SU2.
The code correctly reading everything but as soon as it reaches 'Begin Solver' section, it gives this error!
Sparsh is offline   Reply With Quote
Old   July 14, 2015, 17:36
Andrw Wendorff
awendorff is on a distinguished road
Have you verified that you have run all the test cases without problems? Without more information, it is difficult to determine where the problem might be. You might try to build off of the Onera M6 test cases.
awendorff is offline   Reply With Quote
cfd, su2, su2 error
Problem with pow and volScalarField _Stefan_ OpenFOAM Programming & Development 15 April 14, 2019 23:20
terminate called after throwing an instance of 'int' b614910 SU2 10 July 27, 2014 23:16
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 06:35
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 06:49
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
