fea fsi not supporting parallel whereas other cases suports in version4 |
July 11, 2015, 13:12 |
varghese mathew
Rep Power: 12 |
i ran parallel run for other case its working perfectly but when i ran the standard 3d fsi case in parallel it gave following error
--------------------- Setting Coupling Between Zones -------------------- Set zone boundary conditions (if any). Set zone boundary conditions (if any). Set zone boundary conditions (if any). Set zone boundary conditions (if any). Set zone boundary conditions (if any). Set zone boundary conditions (if any). Set zone boundary conditions (if any). Set zone boundary conditions (if any). ------------------------------ Begin Solver ----------------------------- ================================================== ================================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 139 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ================================================== ================================= YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11) This typically refers to a problem with your application. Please see the FAQ page for debugging suggestions please let me know whether fsi is not built with parallel support |
July 15, 2015, 13:59 |
R. Sanchez
Rep Power: 12 |
Hi, thanks for the interest. The parallel support for multi-zone applications is still under development, so it is not possible to run parallel FSI simulations with the latest release of the code. We are very aware of the importance of parallelization for FSI simulations, so we are working hard towards that direction.
parallel run for fsi simulation??? | smn | CFX | 2 | July 19, 2009 05:04 |
FSI (with a 3rd party FEA software)? | Rui | CFX | 3 | April 17, 2008 18:10 |
FSI and parallel processing | Jorn | CFX | 5 | June 8, 2007 16:53 |
Fluent cases in parallel across multiple machines | Riaan | FLUENT | 3 | April 11, 2005 12:51 |
Parallel Scaling in Unsteady Sliding Mesh Cases | Jonas Larsson | FLUENT | 9 | September 5, 2000 11:13 |
