Home > Forums > Software User Forums > SU2
Axisymmetric Boundary condition
Old   July 9, 2015, 16:02
Default Axisymmetric Boundary condition
mohit
Mohit Singh is on a distinguished road
I have tried a simulation for an axisymmetric body in SU2, but it seems the axisymmetric doesn't work well in SU2 v3.2.8. I have also used one of the mentioned options in the forum itself for the setting the axisymmetric boundary condition, which are:
AXISYMMETRIC = YES
SOUR_NUM_METHOD_FLOW= PIECEWISE_CONSTANT
But the simulation terminates with the message of either termination due to non-physical points or absurd values of C_l and C_d as -10000 and 10000 respectively. Any kind of help will be appreciated.
Is there a problem with the definition of axisymmetric boundary condition ?
Thank you in advance.
Mohit Singh is offline   Reply With Quote
Old   July 14, 2015, 18:05
Thomas D. Economon
economon is on a distinguished road
Hi Mohit,
Have you tried to run a very simple case such as an inviscid supersonic wedge (to see the 3D relieving effect of the axisymmetry)? This may help determine the issue further. There is a 2D mesh in the test cases folder that might be useful for this.
To be clear, the axisymmetric mode in SU2 is meant to be run in pure 2D mode, and it is source term-based, meaning that we add a source term in each cell of the grid during integration, as opposed to applying a boundary condition to a particular marker.
Hope this helps,
Tom
economon is offline   Reply With Quote
Old   July 15, 2015, 10:15
mohit
Hello Sir,
First of all, thanks for your reply and apology for delay in my reply. I will try that case (inviscid supersonic wedge) as guided by you and get back to you if I encounter any issue.
Old   July 15, 2015, 10:19
mohit
Originally Posted by economon View Post
Hi Mohit,
Hope this helps,
Tom
Hello Sir,
Ignore the previous post as it was incomplete and First of all, thanks for your reply and apology for delay in my reply. I will try that case (inviscid supersonic wedge) as guided by you and get back to you if I encounter any issue.It will be very helpful to understand the axisymmetry condition if you could elaborate its meaning as source based term.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
No-slip condition for non-resolved boundary layer in open channel banks Lupocci Main CFD Forum 1 January 17, 2013 04:11
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 03:53
Free-slip boundary condition on 2D axisymmetric beginner FLUENT 1 May 30, 2003 22:44
