Home > Forums > Software User Forums > SU2
actuator disk boundary condition
Old   June 29, 2015, 04:17
Default actuator disk boundary condition
qingxi
lqxymds is on a distinguished road
dear all,
I try to simulate the propeller in SU2 with the actuator disk model. There are something i quite don't understand. Two face markers are to be specified i.e. inlet face marker and outlet face marker. why there are two faces in the actuator model? and what do "rotation_angle_x-axis, rotation_angle_y-axis, rotation_angle_z-axis" refer to?
lqxymds is offline   Reply With Quote
Old   July 14, 2015, 18:12
Thomas D. Economon
economon is on a distinguished road
Thanks for your post. The actuator disk model is relatively new in the code, and we are always interested in hearing from folks that are trying it out.
First, I would like to mention that we have a test case available in the test cases repository that uses the actuator disk BC: https://github.com/su2code/TestCases.../actuator_disk.
To answer your questions, there are two markers specified because in the current implementation, two separate faces (on either side of the disk) are required in the mesh in order to impose the pressure jump that is necessary for the BC. You can find an example mesh and config file specification in that test case directory.
Hope this helps,
Tom
economon is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Outflow boundary condition in cartesian grid SIMPLE velocity-pressure coupling ghobold Main CFD Forum 9 September 19, 2015 03:50
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 19:34
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
