Home > Forums > Software User Forums > SU2
parallel simulations - error message: "OPT_ITERATIONS: invalid option name"
Old   June 23, 2015, 01:27
Default parallel simulations - error message: "OPT_ITERATIONS: invalid option name"
Muhamad Fakhrusy
v8areu is on a distinguished road
hi,
I am trying to do parallel simulations using parallel_simulations.py then I encountered this error
c:\SU2parallel>"C:\python27\python" c:\su2parallel\su2-master\su2_py\parallel_co
mputation.py -f inv_WING.cfg -n 12
OPT_ACCURACY: invalid option name
BOUND_DV: invalid option name
job aborted:
[ranks] message
[0-11] process exited without calling finalize
---- error analysis -----
[0-11] on DELL-PC
C:\SU2parallel\su2-master\su2_py\SU2_CFD ended prematurely and may have crashed.
exit code 1
SU2 process was terminated by signal '3'
I don't have those 3 options on my configuration file inv_WING.cfg
I have tried to add those 3 options to the config file and still encountered the error.
please help about what did I do wrong with the simulation, thanks
I try make another cfg file but still encounter the same error, I checked that I delete those 3 options already.
I attach my cfg file in zip (wing2.cfg)
wing2.zip
glad if you can help me
edit, I try to open the config.py and found this:
#hack - twl
if not data_dict.has_key('DV_VALUE_NEW'):
data_dict['DV_VALUE_NEW'] = [0]
if not data_dict.has_key('DV_VALUE_OLD'):
data_dict['DV_VALUE_OLD'] = [0]
if not data_dict.has_key('OPT_ITERATIONS'):
data_dict['OPT_ITERATIONS'] = 100
if not data_dict.has_key('OPT_ACCURACY'):
data_dict['OPT_ACCURACY'] = 1e-10
if not data_dict.has_key('BOUND_DV'):
data_dict['BOUND_DV'] = 1e10
return data_dict
I don't really understand python so I don't know what that means, but I try delete those things once and encounter another error:
c:\SU2parallel\SU2-master\SU2_PY>"c:\python27\python" parallel_computation.py -f
C:\su2parallel\WING2.cfg -n 12
cstr=WING_1.su2
cstr=WING_1.su2
cstr=WING_1.su2
cstr=WING_1.su2
There is no geometry file (GetnZone))!
cstr=WING_1.su2
cstr=WING_1.su2
cstr=WING_1.su2
cstr=WING_1.su2
cstr=WING_1.su2
job aborted:
[ranks] message
[0] terminated
[1] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 1
[2] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 2
[3] terminated
[4] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 4
[5] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 5
[6] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 6
[7] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 7
[8] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 8
[9] terminated
[10] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 10
[11] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 11
[1-2,4-8,10-11] on DELL-PC
C:\SU2parallel\su2-master\su2_py\SU2_CFD aborted the job. abort code 1
Traceback (most recent call last):
File "parallel_computation.py", line 110, in <module>
main()
File "parallel_computation.py", line 61, in main
options.compute )
File "parallel_computation.py", line 88, in parallel_computation
info = SU2.run.CFD(config)
File "c:\SU2parallel\SU2-master\SU2_PY\SU2\run\interface.py", line 88, in CFD
run_command( the_Command )
File "c:\SU2parallel\SU2-master\SU2_PY\SU2\run\interface.py", line 276, in run
_command
raise exception , message
SU2.EvaluationFailure: Path = c:\SU2parallel\SU2-master\SU2_PY\,
Command = mpiexec -n 12 C:\SU2parallel\su2-master\su2_py\SU2_CFD config_CFD.cfg
SU2 process returned error '1'
v8areu is offline   Reply With Quote
Old   July 16, 2015, 16:08
hlk
Heather Kline
hlk is on a distinguished road
Thanks for your question
The first thing to do is to try using one processor and the files from Quickstart or the TestCases.
It looks like you are using a python script that does not match your SU2_* executables. I say this because it is looking for _#.su2 meshes, which were automatically generated in a previous version. Given the repeated lines of output, it also looks as though the code was not compiled for parallel computation - installation for parallel is covered at https://github.com/su2code/SU2/wiki/Parallel-Build.
To check that the versions match, make sure that "which parallel_computation.py" points to the same bin/ directory as "which SU2_CFD", which will be the directory where you either installed from source or whichever directory you chose for downloaded executables.
If you downloaded the pre-compiled version, make sure you also got the updated python scripts.
hlk is offline   Reply With Quote
Old   July 20, 2015, 19:26
Muhamad Fakhrusy
thanks for the answer, I'll try to check my installation then
to get it working before, I copied the mesh file and renamed the copied one into _1.su2 but it's not a convenient way because every case would take twice the space it should be, so I need to do something about that ...
Old   July 22, 2015, 01:47
Muhamad Fakhrusy
greetings,
I have met another problem again while running in parallel after I've done with the environment variables.
it said like this:
(I type on my command line: python "C:\SU2-4.0.0\SU2-4.0.0\SU2_P
Y\parallel_computation.py" -f turb_SA_flatplate.cfg -n 2)
I'm using Windows 8.1 and just installed the precompiled SU2-4.0.0 and using python script which included in the SU2-4.0.0 master directory that I've downloaded from github. I copied the SU2-4.0.0 master files into my installation folder so that explains the C:\SU2-4.0.0\SU2-4.0.0. the first one is the executables (su2_cfd.exe etc), the 2nd one is the scripts which I've been using to do parallel computation.
W:\KP\tutorial\su2\TestCases\rans\flatplate>python "C:\SU2-4.0.0\SU2-4.0.0\SU2_P
File "C:\SU2-4.0.0\SU2-4.0.0\SU2_PY\parallel_computation.py", line 110, in <mo
dule>
main()
File "C:\SU2-4.0.0\SU2-4.0.0\SU2_PY\parallel_computation.py", line 61, in main
options.compute )
File "C:\SU2-4.0.0\SU2-4.0.0\SU2_PY\parallel_computation.py", line 88, in para
llel_computation
File "C:\SU2-4.0.0\SU2-4.0.0\SU2_PY\SU2\run\interface.py", line 88, in CFD
File "C:\SU2-4.0.0\SU2-4.0.0\SU2_PY\SU2\run\interface.py", line 276, in run_co
mmand
SU2.EvaluationFailure: Path = W:\KP\tutorial\su2\TestCases\rans\flatplate\,
Command = mpirun -n 2 C:\SU2-4.0.0\SU2_CFD config_CFD.cfg
'mpirun' is not recognized as an internal or external command,
operable program or batch file.
any thoughts? I do searched for mpirun throughout my system C: but couldn't find anything outside my Cygwin directory. I've added the Cygwin/bin into the environment variable already.
any answer will be appreciated
Old   July 22, 2015, 08:24
hlk
Heather Kline
Originally Posted by v8areu View Post
greetings,
it said like this:
dule>
main()
options.compute )
llel_computation
mmand
https://github.com/su2code/SU2/wiki/...s-Installation
Old   July 23, 2015, 03:57
Muhamad Fakhrusy
finally I could do the scripts after changing some things in the interface.py script.
SU2_RUN = os.environ['SU2_RUN']
sys.path.append( SU2_RUN )
# SU2 suite run command template
base_Command = os.path.join(SU2_RUN,'%s')
# check for slurm
slurm_job = os.environ.has_key('SLURM_JOBID')
# set mpi command
if slurm_job:
mpi_Command = 'srun -n %i %s'
#elif not which('mpirun') is None: <<<<<
# mpi_Command = 'mpirun -n %i %s' <<<<<
elif not which('mpiexec') is None:
mpi_Command = 'mpiexec -n %i %s'
else:
mpi_Command = ''
I don't know why but those 2 lines seem to gave me the problem. I just add # to make them as a comment. I got mpiexec.exe on my MPI so I guess that's it.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
