Home > Forums > Software User Forums > SU2
pitching simulation
Old   June 16, 2015, 16:36
Default pitching simulation
varghese mathew
varghese9 is on a distinguished road
i am currently using su2 to perform pitching simulation provided in su2 testcase. the problem i am facing is that i have to plot the pitch v/s alpha plot to obtain hystersis plot which i am not getting and what i obtain is a sine curve .i just want help regarding whether the time given in output is in mins and x axis should be alpha=1.01*sin(wt) where w = pitching frequency in rad/s.kindly guide me what i had done wrong. looking forward for some help
varghese9 is offline   Reply With Quote
Old   July 14, 2015, 17:41
Santiago Padron
Santiago Padron is on a distinguished road
The x axis you have is correct, but you have to make sure you have the right time. You know the time step (UNST_TIMESTEP) of the simulation and the number of simulation it ran, from there you can obtain the time. The time output in the history file is in minutes, but that is how long it took your computer to run the simulation.
Santiago Padron is offline   Reply With Quote
Waterbell Simulation o.b.m Fluent Multiphase 1 November 5, 2015 06:55
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 17:06
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 09:22
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
