Viscous calculations for Complex configurations |
June 12, 2015, 05:36 |
Bharatesh
Rep Power: 11 |
Hi all,
I'm trying to run a complex configuration consisting of Wing, Pylon and Store. Did T Rex meshing using Pointwise, and now facing some errors while solving using SU2. Running on a cluster with 2 nodes (24 cores), mesh size is approx 10 million cells. The problem is that, the job gets aborted without even a single iteration. I mean, the job is aborted just before the "Begin Solver" stage, completing all other stages successfully. I'm new to SU2, can someone help me in understanding the problem please..! |
July 6, 2015, 22:03 |
Cleber Spode
Rep Power: 13 |
Have you tried something a little bit simpler, like the onera M6 tutorial first? https://github.com/su2code/TestCases...r/rans/oneram6 Can be a good cfg file example. Have you past for the ---- Geometry Preprocessing ------- step during your run? Big meshes with mixed elements can have hidden problems, it's a tricky problem. |
su2 error |
compressibleInterFoam incl. viscous dissipation heating | vigges | OpenFOAM Programming & Development | 5 | June 10, 2018 07:06 |
Viscous forces (interDyMFoam) differ between OF 2.0 and later versions | maxof | OpenFOAM Running, Solving & CFD | 2 | May 30, 2013 05:17 |
Linearization of viscous flux in discontinuous Galerkin finite element methods | yidongxia | Main CFD Forum | 1 | November 17, 2011 13:11 |
adapt viscous resistance based on velocity / UDF | Häwimeddel | FLUENT | 2 | April 20, 2009 11:08 |
Viscous calculations for airfoil | Chan K I | Main CFD Forum | 5 | March 21, 2001 00:29 |
