Home > Forums > Software User Forums > SU2
Adaptive mesh refinement
Old   June 4, 2015, 23:27
Default Adaptive mesh refinement
firecool1
firecool is on a distinguished road
I am trying to simulate a case of supersonic flow over a Forward facing step. Can Adaptive Mesh Refinement be used in SU2. Can someone explain how this can be accomplished in SU2?
Thanks!
firecool is offline   Reply With Quote
Old   July 14, 2015, 18:25
Thomas D. Economon
economon is on a distinguished road
Yes, we do have mesh adaption capabilities in the code, in particular in the SU2_MSH module.
Unfortunately, we do not have a tutorial available for that feature at the moment. However, you can find the available options in the config_template.cfg file in the root source directory, and there is also a script named mesh_adaptation.py that you will find in SU2_PY/ that you can use to help you get started.
Hope this helps,
Tom
economon is offline   Reply With Quote
amr, supersonic
Adding adaptive mesh refinement to the forwardStep tutorial AlphaSheep OpenFOAM Running, Solving & CFD 10 August 3, 2019 15:40
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] Propeller mesh not smooth nortanapura OpenFOAM Meshing & Mesh Conversion 0 May 16, 2014 04:26
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
