Home > Forums > Software User Forums > SU2
Boundary conditions
Old   May 26, 2015, 04:46
Default Boundary conditions
firecool1
firecool is on a distinguished road
I want to simulate a case of supersonic flow over a forward facing step in a wind tunnel and in the open.
For the case of the wind tunnel these are the boundary condition I want to prescribe.
1. Inlet - Mass flow
2. Bottom(including step) - wall
3. Top - wall
4. outlet - pressure far field
The problem is I do not know which outlet boundary condition corresponds to the pressure far field condition. In fact I unable to figure out what exactly some of the boundary conditions do as I couldn't find much documentation related to it.
For the case of the step in the open, I intend to specify the following boundary conditions.
3. Top - far field
4. outlet - far field
Are these conditions right? I am again uncertain as these worked in a commercial flow solver but doesn't work here.
So please answer at least this question that where can I look for pressure far field boundary condition.
firecool is offline   Reply With Quote
Old   May 26, 2015, 17:24
avar is on a distinguished road
You can use the farfield marker as shown below for farfield pressure boundary condition.
% Marker of the far field (0 = no marker)
MARKER_FAR= ( farfield )
and the marker below for an euler wall boundary condition
% Marker of the Euler boundary (0 = no marker)
MARKER_EULER= ( Wall )
Also the tutorial in the link below should help with the other boundary conditions
https://github.com/su2code/SU2/wiki/...p-in-a-Channel
avar is offline   Reply With Quote
Old   May 26, 2015, 17:26
where the name within the parenthesis is the name you give the boundary in the su2 mesh file. Hope this helps.
Old   May 26, 2015, 23:53
firecool1
Thank You!
boundary condition, pressue far field, step in flow path
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 10:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
