Home > Forums > Software User Forums > SU2
How are aerodynamic coefficients computed in SU2?
Old   May 16, 2015, 05:57
Post How are aerodynamic coefficients computed in SU2?
Amit Kamboj
amitkamboj is on a distinguished road
Hello!
I am solving for axisymmetric flow using 2D grid with four boundaries: inflow, outflow, wall and symmetry. 'history.csv' file is being read to find the lift and drag coefficient for the wall boundary.
I also extracted the pressure and grid points from 'flow.vtk' and manually computed the drag coefficient value. What I have concluded is that the drag value mentioned in 'history.csv' is actually for the 2D planar body even though the flow solved is axisymmetric.
Has anybody else tried it? I want to confirm that this is in fact the case.
Thank you!
amitkamboj is offline   Reply With Quote
Old   May 19, 2015, 17:33
Andrw Wendorff
awendorff is on a distinguished road
In SU2, the 2-D section area is used for the 2-D problem. The areas must be specified by the user. Even for an axi-symmetric problem, the area specified will be the area used by SU2 to calculate the coefficient outputs.
awendorff is offline   Reply With Quote
Old   May 20, 2015, 00:18
Amit Kamboj
I am talking about the area on which the pressure is integrated not the area value used for non dimensionalization.
Thank You.
Old   May 20, 2015, 00:35
Andrw Wendorff
Right. SU2 only knows the area in the mesh. It is not creating a 3-D area due to the axi-symmetric boundary condition.
axisymmetry, planar.
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 12:26
Incorrect calculation of forces/moments coefficients with older versions of SU2 diwakaranant SU2 2 August 16, 2013 05:17
Aerodynamic coefficients daxterss Fidelity CFD 2 April 10, 2012 03:20
[Fluent] Aerodynamic Forces and Coefficients in 180-grid info_bahaider FLUENT 0 January 4, 2012 05:28
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 05:07
