Home > Forums > Software User Forums > SU2
SU2 process returned error '1'
Old   May 15, 2015, 03:50
Unhappy SU2 process returned error '1'
Bharatesh
bharatesh is on a distinguished road
Hey guys,
I'm running a calculation in SU2 in Parallel mode and is a Three dimensional problem with the below info.
12836848 interior elements (12.8 million cells)
12836848 tetrahedra.
2229436 points.
After running 4701 iterations successfully, the process stopped without normal exit. And the error file having 'Traceback(most recent call list)' displays the below error:
MPI: MPI_COMM_WORLD rank 0 has terminated without calling MPI_Finalize()
MPI: aborting job
MPI: Received signal 9
I'm missing the output file Surface_flow.dat file after completing the calculation.
More Details:
Mesh format: .su2 (exported from Pointwise)
Scheme used: JST
Mach no.: 1.2
AoA: 0 degrees
Can somebody help me, as I'm new to SU2 and don't know much about it.
Thanks in advance
bharatesh is offline   Reply With Quote
Old   May 15, 2015, 14:56
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by bharatesh View Post
Hey guys,
2229436 points.
MPI: aborting job
More Details:
Scheme used: JST
Mach no.: 1.2
AoA: 0 degrees
Thanks in advance
Thank you for the question.
Based on your description, it sounds like SU2 exited unusually - for example, the solution may have diverged. You may be able to find out what went wrong by looking at the history file and by looking further back in the output. The error you posted only tells us that SU2 failed - exactly how it failed is usually output as well.
Using the restart files: by copying restart_flow.dat to solution_flow.dat (or whatever file name is indicated in the config file), you can a) restart the solution from the last point that the restart data was saved or b) run SU2_SOL to produce the flow.dat and surface_flow.dat files using the restart data, which will show you what was happening at that point in the solution.
hlk is offline   Reply With Quote
Old   May 20, 2015, 06:42
Default Thanks Heather for your Reply
Bharatesh
I drew the plots for to check the convergence from the history.plt file, and for my surprise, the solution has converged at 1500 iterations itself.
I also did RESTART SOL step and executed, again the calculations stopped abruptly at 4700 iterations
And i tried by changing the command parallel_computation.py to SU2_SOL.cfg in the phBash file, but again I ended up with same problem..
Alternative method followed:
Since the solution was converged at 1500 iterations only, I reduced the Total Number of Iterations to 4000. And luckily the SU2 did exit successfully. And I got the Surface_Flow.dat file too.
su2 error
Question about SU2 optimization YoniHe SU2 Shape Design 3 January 15, 2016 01:31
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 03:40
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 06:28
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
