Home > Forums > Software User Forums > SU2
Divergence issue with SST Turb Model
Old   May 12, 2015, 20:29
Default Divergence issue with SST Turb Model
Jehan Khan
jehanz is on a distinguished road
I am analyzing a propeller of an UAV. I have static thrust measurements such that when I used Euler results I got 3.5 lbf thrust as compared to the measured 6 lbs. My next step was to perform an NS equation with SA turb model. I got 7 times over predicted results such that the mesh has a Y+ of less than 1. Then I thought of doing an SST but was not long enough that it gave me error with divergence. I have been setting up my SST case as per the tutorial example of NACA0012. However, I do not happen to see any entry with regards to eddy frequency etc. (usually required by SST) in the config file. Any guidance will be great.
jehanz is offline   Reply With Quote
Old   May 19, 2015, 17:46
Andrw Wendorff
awendorff is on a distinguished road
You can instead try specifying the FREESTREAM_TURBULENCEINTENSITY, which is set to 0.05 by default, and FREESTREAM_TURB2LAMVISCRATIO, which is set to 10 by default. Both of these options can be set in the config file.
awendorff is offline   Reply With Quote
Old   May 19, 2015, 17:48
Jehan Khan
Thanks
Let me try and will post my results.
Regards,
Old   May 19, 2015, 19:01
Jehan Khan
I tried with:
FREESTREAM_TURBULENCEINTENSITY=0.001
FREESTREAM_TURB2LAMVISCRATIO = 100.0
but I am not sure if these are suitable as I got the following:
Free-stream viscosity (non-dim): 3.61984e-007
Free-stream turb. kinetic energy (non-dim): 0
Free-stream specific dissipation (non-dim): 0
Initialize Jacobian structure (Navier-Stokes). MG level: 0.
Initialize Jacobian structure (SST model).
----------------- Integration and Numerics Preprocessing ----------------
Integration Preprocessing.
Numerics Preprocessing.
Setting dynamic mesh structure.
------------------------------ Begin Solver -----------------------------
Setting rotating frame grid velocities.
Rotational origin (x,y,z): ( 0, 0, 0 )
Angular velocity about x, y, z axes: ( 0, 0, 628.318 ) rad/s
Maximum residual: -4.8402, located at point 57638.
Iter Time(s) Res[Rho] Res[kine] Res[omega] CThrust(Total) C
Torque(Total)
0 149.877000 -6.044197 1.#QNAN0 1.#QNAN0 1.196632e-003 1.77
8442e-003
1 142.350000 -6.044205 -16.000000 -10.059252 1.512296e+000 2.61
1483e+000
2 139.579000 -6.084640 -16.000000 -10.085875 2.813472e+000 4.90
3540e+000
3 138.195750 -6.131297 -15.946917 -9.946917 3.895072e+000 6.87
1384e+000
4 136.817200 -6.180195 -14.692565 -8.692565 4.754986e+000 8.50
6734e+000
5 135.953000 -6.225935 -13.091395 -7.091395 5.397893e+000 9.80
3564e+000
6 135.258000 -6.260035 -11.293994 -5.293994 5.833925e+000 1.07
6124e+001
7 134.779750 -6.273887 -9.338135 -3.338135 6.081352e+000 1.13
9192e+001
8 134.426667 -6.265993 -7.271303 -1.271303 6.164761e+000 1.17
1971e+001
9 134.119100 -6.243379 -5.132733 0.867267 6.115658e+000 1.17
8181e+001
10 134.201455 -6.214587 -2.937581 3.062423 5.966512e+000 1.16
2132e+001
!!! Error: NaNs detected in solution. Now exiting... !!!
It appears I am not seeting the Free stream turb. KE and free stream specific dissipation terms.
Thanks for your help.
divergence, sst, su2
wall treatment k-w SST model in Fluent behest FLUENT 0 December 26, 2014 09:14
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 05:46
Backward facing ramp - SST k-omega model y+ requirements Crank-Shaft Main CFD Forum 0 May 2, 2013 07:07
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 03:43
