May 6, 2015, 09:41 |
"xxxx" is not a CGNS file.
Li Ji
Rep Power: 12 |
Hi, everyone:
I suffered a serious problem about CGNS files. I have a mesh file with CGNS format, but while I launched the SU2_CFD, an error occurred : !!! Error !!! Mesh_1.cgns is not a CGNS file. Now exiting... The mesh file is generated from salome platform, the version of libcgns l is 3.2.1, I configured the SU2 with CGNS correctly. Can anyone help me with this error? Every suggestion is expected! LeeJearl |
May 12, 2015, 17:12 |
David Manosalvas-Kjono
Rep Power: 12 |
Hey LeeJearl,
There are a few options that you have to make sure to hit in order for your CGNS mesh to work. % Mesh input file MESH_FILENAME= mesh.cgns % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= CGNS If you can't find these options or are still getting errors please upload the config file and the mesh and I will take a look. Best, David |
May 12, 2015, 17:38 |
Rep Power: 12 |
LeeJearl,
One more thing to check is if your installation of SU2 is able to run the CGNS test case (https://github.com/su2code/SU2/wiki/...personic-Wedge). If this goes well you should check if you can open your mesh in ADF viewer inside of the CGNS tools to make sure you don't have compatibility issues. Best, David |
May 18, 2015, 22:04 |
#4 | |
Li Ji
Rep Power: 12 |
Thank you for your reply, I think the problem must caused by the hdf5, the SU2 build with not hdf5, but my CGNS file based hdf5 library. Best, LeeJearl |
[swak4Foam] difficulties installing swak4foam | newbie29 | OpenFOAM Community Contributions | 120 | October 21, 2022 05:01 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
