Home > Forums > Software User Forums > SU2
Cantilever beam FSI with SU2
Old   May 5, 2015, 22:16
Default Cantilever beam FSI with SU2
Divyaprakash
Divyaprakash is on a distinguished road
Is there a test case which allows for FSI simulation. I am new to SU2. I need to carry out the simulation of an oscillating cantilever beam placed in a still fluid. Later I'll carry out the same case with the fluid moving. Can someone please guide me on how to proceed with this. Or at least please mention the things I need to go through before I can start with this case.
Divyaprakash is offline   Reply With Quote
Old   May 12, 2015, 17:23
hlk
Heather Kline
hlk is on a distinguished road
Unfortunately we do not currently have a test case for FSI as you describe. You can find some unsteady simulations in the TestCases/unsteady/ folder. These include pitching and plunging 2D cases which prescribe frequencies of the pitching and plunging motion, and a square cylinder case which does not move the geometry but does model the unsteady flow around the square cylinder. For your case you may also want to look into the mesh deformation tools, such as used by the optimization cases.
The SU2 team and others are working on some FSI capabilities however these are not yet ready for use.
hlk is offline   Reply With Quote
beam, cantilever, fsi 2-way coupling, su2
FSI with SU2 akail SU2 4 February 18, 2015 14:12
[solidMechanics] the dynamic response of cantilever beam under earthquake bieshuxuhe OpenFOAM CC Toolkits for Fluid-Structure Interaction 2 May 28, 2014 11:23
one way FSI: large deflection of cantilever beam inside a microfluidic channel o_mars_2010 CFX 1 October 31, 2012 00:17
comsol cantilever beam problem bhu47 COMSOL 0 June 30, 2008 15:59
FSI problem with topology of 3D beam via UDF greg FLUENT 7 July 17, 2006 06:32
