April 29, 2015, 02:13 |
mesh deformation code
varghese mathew
Rep Power: 12 |
i am trying to run a flutter case coupling with su2 and a csd solver .i believe this are the step i should follow
1) run the unsteady su2 cse for time step 1 and get the su2 result file 2) take the file to csd solver as input for pressure load and solve 3) read the file as external file in mesh deformation type in cfg and solve deformation code to obtain new mesh for cfd 4) replace the mesh file and restart the simulation for further time steps i believe this is the method if any available please let me know i also run the code i gt a mesh_motion .dat file which i believe is the file containing the details of displacement right but it contains the details in terms of the node no. and the x y z coordinates which i believe x,y,z are the displacement obtained from the csd analysis but what if the mesh files node no of the csd file and the su2 file does not match is there any option Last edited by varghese9; April 29, 2015 at 05:36. |
April 29, 2015, 14:12 |
#2 | |
Heather Kline
Rep Power: 14 |
In terms of interpolation you may find the following citation useful. Brown, S. A. "Displacement extrapolation for CFD+ CSM aeroelastic analysis." AIAA paper 1090 (1997): 1997. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Mesh deformation not converging with 'GRID_DEFORM_METHOD' as "FEA" | diwakaranant | SU2 | 2 | October 11, 2013 16:51 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
Mesh smoothing and optimization code? | lakeat | Main CFD Forum | 2 | December 3, 2011 08:39 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
