Reading extertnal displacemnt file for grid deformation |
April 6, 2015, 02:36 |
varghese mathew
Rep Power: 12 |
i want to use the external displacement file given by the abaqus as input to the su2 for grid deformation .hw can that be dne .if possible wat shud be the format of the file that contains the displacement values that has to read for grid deformation. help needed if anyone can
April 6, 2015, 14:18 |
#2 | |
Heather Kline
Rep Power: 14 |
It's been a little while since I've used this feature, but if I recall correctly the easiest way to figure out the file format is to run SU2_DEF will all the settings to use an external file but with the specified deformations input file NOT in the working directory. This causes the program to output a file in the correct format, with no deformation. You can then replace the values in that file with your desired values, and run SU2_DEF again. Look through the config_template file in your SU2/ directory to make sure you are using up-to-date options. |
April 7, 2015, 04:11 |
varghese mathew
Rep Power: 12 |
thank you .i will try this option .
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
