March 26, 2015, 04:00 |
fsi coupling with su2 and csd using python
varghese mathew
Rep Power: 12 |
does any body have a idea how to couple two solvers using python.if any body has a copy of that script or document of how it is done .
May 12, 2015, 17:17 |
#2 | |
Heather Kline
Rep Power: 14 |
For examples of calling SU2 with python please see the scripts in the SU2_PY folder of the source code. Then you must convert the SU2 output files to the inputs needed by the second solver (if you are using two solvers within SU2 this only requires changing the file names). For fluid-structure-interaction specifically, the SU2 team and others are working on some FSI capabilities however these are not yet ready for use. |
