March 3, 2015, 12:27 |
Wall functions in SU2
Rep Power: 13 |
Dear all,
I am looking at the implementation of wall models (for now for the SA model) in SU2. The strategy I wanted to use is:
I applied this method to the turbulent flat plate test case, with a fine mesh (y = 1e-6 at the first cell, y+ << 1) and a coarse one (y = 1e-3, y+ \approx 100). Results are attached: it seems that at the first point off the wall the wall shear stress is computed correctly from the velocity and wall distance, and that the value of nutilda is imposed correctly. However, the eddy viscosity in the BL is overestimated and the BL is too thick. What am I doing wrong? Best regards Xavier u.png u2.png nut.png |
March 5, 2015, 20:45 |
Francisco Palacios
Rep Power: 15 |
Thanks Xavier,
This is an important implementation in SU2. It would be great if you could work on a GitHub branch (we can give you access). In fact, we started the implementation of the wall functions some time ago in https://github.com/su2code/SU2/tree/...Wall_Functions it would be great if we work in a coordinate way. In you are interested, just send me an email fpalacios_at_stanford.edu Best Regards, Francisco SU2 lead developer |
March 26, 2015, 08:52 |
Rep Power: 13 |
Dear Francisco,
The emails I try to send you are not delivered. Could you please email me at xgarnaud_at_gmail_dot_com? Thank you very much, Xavier |
March 6, 2017, 15:50 |
Oliver V
Rep Power: 10 |
I'm wondering if the wall functions were added to any more recent version of SU2. Thanks. Oliver |
su2, wall functions |
Wall functions - questions about implementation | AlmostSurelyRob | OpenFOAM Programming & Development | 44 | May 6, 2020 11:11 |
Boundary Field and Wall Functions, time 0 & time >0 | NJG | OpenFOAM Running, Solving & CFD | 1 | April 5, 2013 11:48 |
wall functions implementation | besh | OpenFOAM Programming & Development | 0 | January 1, 2013 10:14 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
Wall Functions | pierre | OpenFOAM Running, Solving & CFD | 0 | October 1, 2005 14:13 |
