Home > Forums > Software User Forums > SU2
Non-physical behavior in internal flow (two inlet --> one outlet)
Old   February 11, 2015, 16:38
Default Non-physical behavior in internal flow (two inlet --> one outlet)
Chintan Patel
chintan is on a distinguished road
I'm solving a film cooling problem with one hole and I'm getting non-physical behaviour inside hole and one of the inlet.
I have been trying to solve these for few months now. It doesn't converge at all. (after 15 hours of simulation on 20 of 2.4 GHz cores, density residual is still -0.9)
Problem:
inlet: -hot gas: mass flux (from yz plane i.e. only x velocity)
-coolant: mass flux (from xz plane ie only y velocity)
outlet: -hot gas+coolant: back pressure (from yz plane)
Issues:
1. Velocity inside hole in extensively large.
2. Bottom inlet has some velocity components going out of boundary.
[Images]
https://drive.google.com/file/d/0BzU...ew?usp=sharing
[configuration file]
My questions are: a. Am I doing something wrong? (configuration file linked above) b. If not, can su2 solve this kind of problem? (it seems fairly possible but test cases doesn't have internal flow problems except flat plate with a bump!) I would appreciate any help to address/identify the issue.
chintan is offline   Reply With Quote
Old   February 18, 2015, 14:40
Francisco Palacios
fpalacios is on a distinguished road
In principle, SU2 should be able to solve this problem.
Could you please share the .su2 mesh?
Thanks!
Francisco Palacios
SU2 lead developer
fpalacios is offline   Reply With Quote
Old   February 18, 2015, 14:52
Chintan Patel
Hi Francisco,
Here is link for the mesh I'm using for test case.
Old   February 18, 2015, 15:04
Chintan Patel
I want to note that I have tried both Total quantities and mass flux as inlet BC.
Also tried simplified cases like no turbulence, Euler equations etc. But I could never achieve convergence (and roughly, based on changes in residuals, it will not converge even after 10 days of computations with noted cores!)
Also, I got density residual about 1e-2 for test case with 1M cells, but then convergence stops. Momentum residuals stay in range of 1e3 to 1e5 and don't reduce.
divergent, internal flow
Internal Flow BCs for Compressible inlet flow Katie FLUENT 2 March 3, 2012 18:35
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 13:41
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Duct Flow with 90 degree inlet and outlet k FLUENT 3 August 19, 2007 15:30
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
