Changing the number of significant figures in surface files written by SU2_DEF |
February 10, 2015, 05:22 |
Zeno
Rep Power: 13 |
Hello everyone,
is there a way to change the number of significant figures in the files created by SU2_DEF? (Surface_Grid.plt, Surface_Grid.stl, Volumetric_Grid.plt) I have noticed the number of significant figures of the .su2 mesh file is much larger than that for the above mentioned files. Thanks, Z |
February 11, 2015, 14:04 |
#2 | |
Heather Kline
Rep Power: 14 |
I think this can be changed in the output_structure.cpp file. (this will require much searching for the appropriate lines re-compiling the code) |
February 16, 2015, 05:25 |
Zeno
Rep Power: 13 |
Dear Heather,
Thank you for your reply. I found out the specific line to change is in output_tecplot.cpp, under the voice "Tecplot_File.precision(###)", where ### is the number of significant figures you want to use. Best wishes, Z |
significant figures, su2_def |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
