Home > Forums > Software User Forums > SU2
FSI,su2
Old   February 10, 2015, 05:10
Unhappy FSI,su2
varghese mathew
varghese9 is on a distinguished road
does any body know the procedure to do fluid structure interaction problem in su2.i dont know how to link the solid and fluid mesh .in unsteady analysis .caan any body give me a copy of how the fsi cfg files look like and the instructions to solve the problem .really looikng for solution ...................
varghese9 is offline   Reply With Quote
Old   February 11, 2015, 14:17
hlk
Heather Kline
hlk is on a distinguished road
Thanks for your question.
Linking solid and fluid meshes it is not included yet. We are working on something related, but I can't give you an estimate on when that will be ready.
If you want a 2-d case with specified rigid motion, there is a sample in TestCases/unsteady/pitching_naca64a010_euler. In order to use the FLUID_STRUCTURE setting there (which is only for 2d airfoils in pitch and plunge motion) I recommend looking through the source code to understand what the required settings are.
hlk is offline   Reply With Quote
Old   February 12, 2015, 00:50
varghese mathew
i read the code in the iterative structure and understood the code little bit i dont know how to get two zones(zones_0 and zone_1 )
there should be some code or config command to link this file i belive
