Home > Forums > Software User Forums > SU2
Calculating yplus
Old   February 5, 2015, 18:34
Default Calculating yplus
Doug Hunsaker
doug is on a distinguished road
Is there a way to report yplus along a surface in SU2, just like pressure and skin friction are reported? Or do I need to manually compute yplus along the surface?
doug is offline   Reply With Quote
Old   February 10, 2015, 22:13
hlk
Heather Kline
hlk is on a distinguished road
for 3D navier stokes or rans the yplus value is output to the restart file. You can then get the value on the surface in post processing, or alter the source code to add this output to the surface file.
hlk is offline   Reply With Quote
Old   February 10, 2015, 22:41
Doug Hunsaker
Thanks Heather. What about for 2D? I'm only doing 2D right now and I don't see yplus in any of the outputs including the restart file.
Old   February 10, 2015, 22:58
hlk
Heather Kline
set LOW_MEMORY_OUTPUT = NO
Old   February 11, 2015, 15:10
Doug Hunsaker
Worked like a charm. Thanks!
su2, yplus
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Calculating the yPlus value for SA-model simulation Siren OpenFOAM 2 July 3, 2012 11:38
Calculating mass flow and Yplus values petrile_83 OpenFOAM Post-Processing 1 December 17, 2011 11:37
Calculating YPLUS and Compiling Multiple C files sanjibdsharma OpenFOAM Programming & Development 1 August 11, 2009 07:56
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
