Home > Forums > Software User Forums > SU2
Problems about cd values of NACA0012
Old   January 30, 2015, 10:48
Default Problems about cd values of NACA0012
Yang Muchen
ymc11 is on a distinguished road
Hello everyone,
I did some simulations of NACA0012 airfoil using SU2. I used the grid in testcases/rans/naca0012/mesh_NACA0012_turb_897*257.su2 and SST turbulent model. The angle of attack is 15deg. However, the cl value(1.499) matchs well with the experiment(1.5), but the cd(0.028845) is much larger than the experiment value(0.018).
Could anyone please help me? Thanks a lot!
ymc11 is offline   Reply With Quote
Old   February 4, 2015, 20:13
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by ymc11 View Post
Hello everyone,
Did it match at lower angles of attack?
At a 15 degree angle of attack there could easily be separation and unsteady effects in the experimental results. Also, note that turbulence effects are generally difficult to match between experiment and CFD, and will likely require tuning of the turbulence model parameters as well as making sure that the mesh is appropriately refined (look up "y+" on cfd-online if you are not familiar with that).
hlk is offline   Reply With Quote
Old   February 16, 2015, 14:05
D L
DLuo is on a distinguished road
Hi Yang,
CLMax for this airfoil in 2D is around 13 degrees. CFD in it's current state, especially with RANS solutions is not well suited for predicting performance in the stall regime. Like Heather mentioned, at that angle there's a reasonable amount of separation and unsteadiness therefore a RANS solution by definition (Reynold averaged NS) wouldn't be the proper method of prediction.
For more reading on the subject I suggest reviewing the results from AIAA High Lift Prediction workshops
DLuo is offline   Reply With Quote
Convergence problems using extreme coefficient values like 1e-16 with porous jump recepky FLUENT 3 November 11, 2017 03:12
[BEGINNER] Problems running tutorials (incompressible) in OF 2.xx Jaro OpenFOAM Running, Solving & CFD 8 March 16, 2016 08:27
Problems with the values of "OBJFUNC_SCALE" Fang-SIAMM SU2 1 April 11, 2013 14:27
exact face values RubenG Main CFD Forum 0 June 22, 2009 12:09
Values of k and e for multiphase problems!! zack FLUENT 0 January 28, 2006 03:16
