Simulation of hypersonic flow: NaN in the residual |
January 26, 2015, 01:43 |
David Hwang
Rep Power: 12 |
Hi guys,
I have just begun using SU2, which I hope I can use to simulate hypersonic flow with real gas effects. I assumed that is possible, because I noticed the existence of TNE2 module in SU2. I have tried the RAMC-II test case and ran a Mach 12 double-wedge airfoil case for Euler solution. They worked well. However, when I try to get RANS solution of the double-wedge case, I get this error Code:
------------------------------ Begin Solver ----------------------------- !!! Error: There is a NaN in the residual. Now exiting... !!! Code:
FREESTREAM_TEMPERATURE= 220.61 REYNOLDS_NUMBER= 8.07145E7 REYNOLDS_LENGTH= 1.0 Code:
Specific gas constant: 287.058 N.m/kg.K. Free-stream pressure: 20646.1 Pa. Free-stream temperature: 220.61 K. Free-stream density: 0.326019 kg/m^3. Free-stream velocity: (3573.08, 0) m/s. Magnitude: 3573.08 m/s. Free-stream total energy per unit mass: 6.54177e+06 m^2/s^2. Free-stream viscosity: 1.44323e-05 N.s/m^2. Code:
PHYSICAL_PROBLEM= NAVIER_STOKES KIND_TURB_MODEL= SA VISCOSITY_MODEL= SUTHERLAND MARKER_HEATFLUX= ( UPPER, 0.0, LOWER, 0.0 ) % Wall BC MARKER_FAR= ( INLET, OUTLET ) % Farfield CONV_NUM_METHOD_FLOW= ROE SPATIAL_ORDER_FLOW= 2ND_ORDER SLOPE_LIMITER_FLOW= VENKATAKRISHNAN TIME_DISCRE_FLOW= EULER_IMPLICIT CONV_NUM_METHOD_TURB= SCALAR_UPWIND SPATIAL_ORDER_TURB= 2ND_ORDER SLOPE_LIMITER_TURB= VENKATAKRISHNAN TIME_DISCRE_TURB= EULER_IMPLICIT Code:
There are 4 non-physical states in the upwind reconstruction. Thank you in advance! Danny Last edited by smanist; January 26, 2015 at 01:45. Reason: Typos |
January 26, 2015, 19:05 |
#2 | |
Heather Kline
Rep Power: 14 |
Thank you for your question
For changing the flight conditions, please note that the solution will be sensitive to the quality of the mesh, and that a mesh that is well tuned for a particular Reynolds number and Mach number may not perform well at other conditions due to not having enough refinement in the boundary layer or near shocks. Similarly, when switching between models a different mesh may be needed - especially when switching between an inviscid (euler) and viscous model (rans). If you have not done so already, I recommend making a new mesh for the wedge which has y+ <= 1 at the wall. (cfd-online has a calculator that can help with this at http://www.cfd-online.com/Tools/yplus.php). Quote:
January 26, 2015, 22:03 |
David Hwang
Rep Power: 12 |
I see! Thanks for your advice. Let me refine my mesh.
buoyantSimpleFoam and watertank | Tobi | OpenFOAM Running, Solving & CFD | 100 | December 18, 2022 09:15 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) | Scabbard | OpenFOAM Running, Solving & CFD | 1 | July 22, 2014 05:50 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
