Home > Forums > Software User Forums > SU2
code problems at boundary junctions
Old   January 21, 2015, 21:56
Post code problems at boundary junctions
Ying Zhuying
zylanboluo is on a distinguished road
Hello,everyone!
When I simulated a 2D 2Ma wedge flow field with SU2 using NS governing equations, I found the result was wrong on boundary junctions. I set left and upper boundaries as farfield, right boundary as outflow, and lower boundary as NS wall. The result was wrong at the lower-left corner and the lower-right corner. At the lower-right corner, the pressure decreases suddenly for no reason,and the lower-right corner is treated as a bump.
Why this wrong result happened? Code problems or something else?
I have also tested the tutorial "Turbulent Flat Plate", and found this problem at lower-right corner,the junction of outlet and NS wall.
zylanboluo is offline   Reply With Quote
Old   May 12, 2015, 17:49
JAE HWAN CHOI
chamsolli is on a distinguished road
HI,
I think that the problem at the lower-left corner is due to boundary condtiion.
Since you're imposing NS-Wall for whole lower boundary, you may face sudden decrease in pressure at thw lower-left corner.
I recommend you to divide the lower wall into two sections and imposing symmetry condition for the first section and NS-wall for the other section.
I'm not quite sure what's going on at the lower-right corner but I'd recommend to use high resolution mesh for NS simulation near the wall.
I hope this helps!
Best,
Jae Hwan Choi
chamsolli is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
