Home > Forums > Software User Forums > SU2
Checking whether a node belongs to wall boundary(HEATFLUX_BC).!)
Old   January 5, 2015, 05:13
Smile Checking whether a node belongs to wall boundary(HEATFLUX_BC).!)
Vino
Vino is on a distinguished road
I would like to do some corrections in wall boundary (no-slip) . Is there any way to identify whether a node is from wall boundary(HEATFLUX_BC)?
I tried the following.
bool boundary = geometry->node[iPoint]->GetPhysicalBoundary();
but it checks for all the boundaries. Is there any specific way to check for only wall boundaries.
Thanks.!!!
Vino is offline   Reply With Quote
Old   January 5, 2015, 15:40
Thomas D. Economon
economon is on a distinguished road
Dear Vino,
Although we don't use it very often, please try the following to search for solid wall boundaries (Euler, isothermal, heat flux):
bool boundary = geometry->node[iPoint]->GetSolidBoundary();
Hope this helps,
Thomas D. Economon
SU2 lead developer
economon is offline   Reply With Quote
Old   January 7, 2015, 11:32
Vino
Thanks for you reply.
I tried the option: bool boundary = geometry->node[iPoint]->GetSolidBoundary();
I found it is not detecting any boundaries including EULER, HEATFLUX and ISOTHERMAL WALL.
I suspect there may be a bug in this. Can you tell me whether this function ( GetSolidBoundary() ) anywhere used in the code.
Thank you.
Old   January 16, 2015, 04:11
Thomas D. Economon
Can you please try this again with the 'develop' branch (the most recent developer version of the code)? I think that a fix for this was recently applied: https://github.com/su2code/SU2/tree/develop.
Cheers,
Thomas D. Economon
SU2 lead developer
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Radiation interface hinca CFX 15 January 26, 2014 18:11
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
