Home > Forums > Software User Forums > SU2
3d flutter
Old   December 22, 2014, 04:33
Smile 3d flutter
varghese mathew
varghese9 is on a distinguished road
hello everyone first of all i am a fresher trying to simulate flutter in 3d case of a wing .i have successfully done the flutter case for 2d using the inbuilt programme in su2_aero-elasticity.i want to know is it possible to built a coupled model of cfd and fem in the su2 model using a single configuration file.can i built the solid model and solve it using the fem solver and input the output to the fem to cfd for mesh deformation and cfd analysis using the single cfg file for both .and can the interface be built using python code .kindly reply
varghese9 is offline   Reply With Quote
Old   January 1, 2015, 20:07
Francisco Palacios
fpalacios is on a distinguished road
The most active group working in that area are
http://su2.stanford.edu/teams/IC_Team.html
or
http://qub.ac.uk/research-centres/ca...2MPCCINastran/
Maybe you can contact them,
Best regards,
Francisco Palacios
SU2 lead developer
fpalacios is offline   Reply With Quote
Old   January 20, 2015, 05:14
Default fea solver
varghese mathew
thank you .I have recently gone through the fea solver where i have few dobts as stated below.kindly guide me through
1 can a solution file of cfd be linked as input to fea solver is there any provision made for that and vice versa because that may help me in importing the pressure file onto the nodes of structure surface of wing and if so whats the format.how to link each data sol in unsteady case from cfd to fea
2.the fea solver is currently only providing von mises stress as output rather than displacements .is thier any way to get this displacements values as output
3 there is one bc_flow pressure boundary condition what does that stand for in fea solver and how does that work
kindly help me with answers if possible
Old   January 23, 2015, 12:56
R. Sanchez
rsanfer is on a distinguished road
thanks for your interest. The FEA solver is currently under intense development and testing and thus has not been merged yet into the release version of the code. We expect to do it shortly, with brand new features. On its latest beta version the FEA solver generates both displacements and stress fields as outputs. The bc_flow pressure boundary condition is also currently being reformulated.
Best regards,
Ruben Sanchez
rsanfer is offline   Reply With Quote
Old   January 27, 2015, 00:53
varghese mathew
ok thanks a lot .expecting that there would be some options for 3d flutter analysis also .but all together the software is very good
Old   January 28, 2015, 03:56
varghese mathew
i ran the beam problem for latest su2 3.2.7 .it seems like it doesnot provide displacement as output
TITLE = "Visualization of the surface solution"
VARIABLES = "x","y","Conservative_1","Conservative_2", "Von_Mises_Stress", "Flow_Pressure"
ZONE NODES= 436, ELEMENTS= 436, DATAPACKING=POINT, ZONETYPE=FELINESEG
0.000000e+00 -1.000000e-02 4.857543e-04 -1.277594e-02 1.003697e+06 0.000000e+00
1.758794e-03 -1.000000e-02 4.857510e-04 -1.269056e-02 9.932117e+05 0.000000e+00
3.517588e-03 -1.000000e-02 4.346568e-04 -1.277593e-02 1.011840e+06 0.000000e+00
5.276382e-03 -1.000000e-02 4.857477e-04 -1.260519e-02 1.003343e+06 0.000000e+00
8.793970e-03 -1.000000e-02 3.835593e-04 -1.277593e-02 1.020270e+06 0.000000e+00
1.055276e-02 -1.000000e-02 4.857441e-04 -1.251981e-02 1.045352e+06 0.000000e+00
1.582915e-02 -1.000000e-02 3.324621e-04 -1.277592e-02 1.012095e+06 0.000000e+00
1.758794e-02 -1.000000e-02 4.857397e-04 -1.243443e-02 1.127047e+06 0.000000e+00
2.462312e-02 -1.000000e-02 2.813652e-04 -1.277592e-02 9.821737e+05 0.000000e+00
2.638191e-02 -1.000000e-02 4.857339e-04 -1.234905e-02 1.257821e+06 0.000000e+00
3.517588e-02 -1.000000e-02 2.302688e-04 -1.277592e-02 9.304990e+05 0.000000e+00
3.693467e-02 -1.000000e-02 4.857263e-04 -1.226367e-02 1.444182e+06 0.000000e+00
4.748744e-02 -1.000000e-02 1.791727e-04 -1.277591e-02 8.594749e+05 0.000000e+00
4.924623e-02 -1.000000e-02 4.857166e-04 -1.217828e-02 1.688509e+06 0.000000e+00
6.155779e-02 -1.000000e-02 1.280770e-04 -1.277591e-02 7.727136e+05 0.000000e+00
6.331658e-02 -1.000000e-02 4.857042e-04 -1.209290e-02 1.990227e+06 0.000000e+00
7.738693e-02 -1.000000e-02 7.698149e-05 -1.277590e-02 6.744497e+05 0.000000e+00
7.914573e-02 -1.000000e-02 4.856890e-04 -1.200752e-02 2.347512e+06 0.000000e+00
9.497487e-02 -1.000000e-02 2.588617e-05 -1.277590e-02 5.692429e+05 0.000000e+00
9.673367e-02 -1.000000e-02 4.856704e-04 -1.192214e-02 2.758377e+06 0.000000e+00
1.143216e-01 -1.000000e-02 -2.520909e-05 -1.277590e-02 4.618148e+05 0.000000e+00
1.160804e-01 -1.000000e-02 4.856481e-04 -1.183676e-02 3.221110e+06 0.000000e+00
1.354271e-01 -1.000000e-02 -7.630441e-05 -1.277590e-02 3.569483e+05 0.000000e+00
1.371859e-01 -1.000000e-02 4.856217e-04 -1.175138e-02 3.734370e+06 0.000000e+00
1.582915e-01 -1.000000e-02 -1.273999e-04 -1.277590e-02 2.594146e+05 0.000000e+00
how can we get flutter speed from 2way fsi?? siddu.pk ANSYS 2 January 22, 2014 23:35
Does Fluid Structure Coupling between CFD-FEM solves can predict Flutter Speed? Engr.RZA Main CFD Forum 1 December 10, 2012 19:45
FSI and flutter pop CFX 11 July 26, 2011 12:48
Two questions concerning flutter? lakeat Main CFD Forum 3 April 7, 2011 11:21
Vortex shedding and aeroelastic flutter question Freeman FLUENT 2 March 20, 2009 08:19
