Home > Forums > Software User Forums > SU2
TNE2_Euler Solver Error
Old   December 15, 2014, 04:34
Question TNE2_Euler Solver Error
wel
Welly
wel is on a distinguished road
Greetings All,
I'm working on a VnV project for SU2 with particular interest in TNE2_Euler solver. I need help resolving an error when running the case using TNE2_Euler solver.
Details:
Geometry: Blunted Cone with 20 deg half angle
Preprocessing:The mesh is exported from ICEM (.cgns format) [https://drive.google.com/file/d/0Byo...w?usp=sharing]
Configuration file:
ConfigurationFile.txt
Quick ref: M=5.8 and Re=330,000
Error in terminal:
SU2_RunCase.txt
Already tried:
a) Refining mesh through-out domain and along shock wave.
b) Changing first cell height based on y+ values which I taken to be 1.
c) Varying CFL number, linear solver iterations, Free-stream temperature.
*Have been able to run the case successfully using Euler and NS solvers.
Seeking advice on how I could resolve this.
Thanks in Advance.
wel is offline   Reply With Quote
Old   January 1, 2015, 20:16
Francisco Palacios
fpalacios is on a distinguished road
The TNE2 solver has been implemented and validated in a Git branch. We will move it to the master very soon. If you are interested, you can directly contact the main developer. https://adl.stanford.edu/people/copeland.html
Best Regards,
Francisco Palacios
SU2 lead developer
fpalacios is offline   Reply With Quote
tne2 euler
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
