finite_differences.py & continuous_adjoint.py |
Zeno
Rep Power: 12 ![]() |
hello everyone,
I would like to check the adjoint gradients against the FD ones. To do so I use the python scripts to compute the gradients. However, I would like to save some time by avoiding to compute the direct solution since I already have that results stored in a solution_flow.dat file from previous simulations. Is there a way to deactivate the computation of the direct solution? Thanks in advance, Z |
Francisco Palacios
Rep Power: 15 ![]() |
Maybe you can just adjust the convergence criteria (changing RESIDUAL_MINVAL)... so the solver will only perform a couple of iterations.
Best Regards, Francisco Palacios SU2 lead developer |
adjoint, finite differences, gradient |
