Home > Forums > Software User Forums > SU2
Validation test case issue
Old   November 17, 2014, 06:55
Post Validation test case issue
Zen
Zeno
Zen is on a distinguished road
Hello everybody,
I am validating SU2 for the simulation of junction flows. I am woriking on the following ERCOFTAC case (http://cfd.mace.manchester.ac.uk/cgi...html&1&0&0&0&0)
I have generated my own mesh with Pointwise according to the guidelines given on the website (let me know if you need the file).
When I simulated the case with version 3.2.0 I got sufficiently satisfying results, In particular the size of the horseshoe vortex is OK (see image).
However, I have some issues with v.3.2.2 since the size of the horseshoe vortex is way smaller than expected (see image).
I've attached the configuration files I used for the simulations with the two different versions of SU2. There is no major difference between the settings I used to simulate the case with the two versions.
I am now trying to figure out why this happened and any help is appreciated very much. In the mean time I've downloaded the latest version of SU2 (v.3.2.3) and I am running simulations with this version as well, I will update you soon.
Thank you in advance,
Z
Zen is offline   Reply With Quote
Old   November 21, 2014, 09:10
Zen
Zeno
Problem was the results were not fully converged.
ercoftac, horseshoe, junction flows
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Heat Transfer Validation test case Chris Whitney Main CFD Forum 1 July 21, 1999 15:36
