Help: 3D mesh adaptation for nozzle-wake problem |
Nitin
Rep Power: 12 ![]() |
I wish to perform mesh adaptation on a simple 3D circular nozzle-wake problem with supersonic flow. Attached is a steady state result from SU2 (version 3.2.4) showing pressure distribution. I searched for a mesh adaptation tutorial/procedure in this forum; however, I could not find one. Is there a formal test case that illustrates the steps involved for mesh adaptation? If not, will it be possible to enumerate the procedure? Thank you for your help. -Nitin. |
mesh adaption |
[GAMBIT] SOFC crossflow mesh possible problem??? | epc1 | ANSYS Meshing & Geometry | 1 | February 4, 2013 01:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
