Dimitar Baldzhiev
Rep Power: 11 ![]() |
I'm running su2 on Windows7 and I have no problems at all with the single threaded runs but when I try to run parallel I get this problem.
I assume the problem is with my conf file so you can have a look at it here https://dl.dropboxusercontent.com/u/...v_NACA0012.cfg If I run it without -divide I get the same error but instead of su2_cfd the problem is with su2_prt. I am fairly convinced that my mpirun and openmpi are configured correctly. Code:
PS C:\SU2\test> parallel_computation.py -f .\inv_NACA0012.cfg -n 8 -divide 8 total processes failed to start SU2 process was terminated by signal '125' -------------------------------------------------------------------------- mpirun was unable to launch the specified application as it could not access or execute an executable: Executable: C:\SU2\SU2_CFD Node: BELISKNER while attempting to start process rank 0. Thanks Very much! |
Welly
Hello!
The error could be because of ".\" prefixed to inv_NACA0012.cfg, this would mean its an executable. While I work on a different platform I could produce an error by using .\inv_NACA0012.cfg. Try this: parallel_computation.py -f inv_NACA0012.cfg -n 8 -divide Let me know if it works! |
Dimitar Baldzhiev
Same error
Chris L
i think you need Windows Server OS, or maybe at least Windows 7 Ultimate.
when I tried going through the installation guidlines for multiprocessor setup, I ran into a message indicating I need Windows Server installed. (It's been a while, so I don't remember exactly what the message was, but I remember that it became clear I couldn't use mulitple cores unless I spent money upgrading my OS.) I've since decided to buy a new system (through my new company) and am trying to figure out if Windows 7 Ultimate 64-bit OS will suffice. |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SU2 in parallel | suman91 | SU2 | 4 | September 26, 2014 20:38 |
parallel computation with SU2 V3.2 | 454514566@qq.com | SU2 | 1 | June 24, 2014 20:46 |
Parallel SU2 | samiam1000 | SU2 | 5 | February 16, 2013 00:41 |
Access patch points (on different processor) in parallel | Arnoldinho | OpenFOAM Programming & Development | 7 | September 11, 2012 05:55 |
