Home > Forums > Software User Forums > SU2
stl to su2 programatically
Old   November 6, 2014, 09:23
Default stl to su2 programatically
Dimitar Baldzhiev
dbaldzhiev is on a distinguished road
I'm architecture student in my final year. I want to interface cfd analysis in Rhino Grasshopper for wind tunnel analysis. I after some searching I found out that SU2 may be most appropriate for that. Have in mind that I'm cfd newbie.
So far I have installed SU2 and I can run the examples. In grasshopper I have a script that can easily export a mesh as a STL. I have problem converting STL to SU2 mesh-files with a script. Basically I'm looking for a library that will convert the mesh in .su2.
I think running the solver programatically wont be really the problem, and the post-processing of the results would be generally straightforward, but if you think there might be problems that I don't currently realize, please elaborate.
Grasshopper supports c#, vb.net, python so if the library is directly compatible with .net it will be even better.
Any suggestions, or tips that come to your mind would be also greatly appreciated.
dbaldzhiev is offline   Reply With Quote
cfd, grasshopper, meshing, postprocessing
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 15:55
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 03:40
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 06:28
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh Irish09 OpenFOAM Meshing & Mesh Conversion 9 April 7, 2012 09:50
