October 23, 2014, 10:37 |
Roe-Turkel Preconditioning
Zeno
Rep Power: 13 |
When I try to use the Roe-turkel scheme to accelerate convergence the solution does not converge, whereas if I use a normal Roe scheme without preconditioning I get a converged solution but after a long time. In particular, if I use FGMRES I get the following error: !!! Error: The FGMRES solver has diverged. Now exiting... !!! If I use BCGSTAB I get non-phyiscal points in the solution and the solver stops. Any idea why? Z Last edited by Zen; October 23, 2014 at 11:49. |
October 24, 2014, 00:24 |
#2 | |
Heather Kline
Rep Power: 14 |
It is difficult to tell from little information, but you may want to check the quality of your mesh. It is also a good idea to double-check the boundary conditions. Please refer to the test cases (the su2code/TestCases github repository) for examples of config files for various conditions. |
conservative variables, sst |
FSAS coefficient in k-omega SST SAS model | vkrastev | OpenFOAM Running, Solving & CFD | 9 | October 25, 2018 09:09 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 14:48 |
Production correction or curvature correction in the SST model | Ang | CFX | 2 | May 20, 2014 21:50 |
Backward facing ramp - SST k-omega model y+ requirements | Crank-Shaft | Main CFD Forum | 0 | May 2, 2013 07:07 |
why SST model??? | vijay | CFX | 3 | May 22, 2008 04:05 |
