Home > Forums > Software User Forums > SU2
Total_MaxHeat vs Surface Maximum Heat Flux
Old   October 5, 2014, 05:25
Default Total_MaxHeat vs Surface Maximum Heat Flux
Jeffrey van Oostrom
Doriris is on a distinguished road
Hello developers,
I have yet another question regarding the heat fluxes. I've been digging through the code for a few days now, trying to figure out why the maximum heat flux that is in my surface_flow.dat is way different from the Total_MaxHeat that is exported in the history file.
There are a few differences I can find in the code. First of all, in the surface file, the routine calls Aux_Heat[iPoint] = solver[..]->GetHeatFlux(iMarker, iVertex) whereas the history file routine calls Total_MaxHeat = solver[..]->GetTotal_MaxHeatFlux();.
In solver_direct_mean.cpp the HeatFlux is computed after which the Heat_Visc += HeatFlux*Area; and MaxHeat_Visc += pow(HeatFlux, MaxNorm);, where MaxNorm is equal to 8.0. Then, the root is taken again of MaxHeat_Visc and is assigned to Total_MaxHeat.
So what is the difference between the normal HeatFlux and the Total_MaxHeat or Total_Heat? The latter are probably both integrated? Is there any way to get the correct maximum HeatFlux in the history file?
Thanks for your reply,
Jeffrey
Doriris is offline   Reply With Quote
Old   October 16, 2014, 12:56
Jeffrey van Oostrom
Hi again,
Does anyone have a clue about my question above?
Thanks!
Jeffrey
Radiation interface hinca CFX 15 January 26, 2014 18:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
