Running SU2 Pyhton Script in Parallel with PBS Torque |
Y Yang
Rep Power: 13 ![]() |
Dear All,
In this https://www.youtube.com/watch?v=XJO86GXU1Vo&t=7m25s, it was explained about how to run parallel processing by either run parallel_computation.py or call SU2_PRT, SU2_CFD, and SU2_SOL with mpirun manually (since installing python on cluster maybe cumbersome). By any chance, if I want to run other Python script (not only do parallel computation for example: parallel_polar_targetCL_inc.py) in cluster by PBS Torque, how should I do it? Regards, Yosheph Yang |
#2 | |
Heather Kline
Rep Power: 14 ![]() |
For the other provided python scripts, you can find information about the required command-line inputs by typing {scriptname.py} --help Additional information is at: http://adl-public.stanford.edu/docs/...ED/Running+SU2 |
interFoam process forking on HPC using PBS | JFM | OpenFOAM Running, Solving & CFD | 2 | February 4, 2014 08:49 |
SU2 parallel running error,help~~~ | nuaawubin | SU2 Installation | 5 | January 30, 2014 17:18 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
TASCflow,problem with script and parallel mode | Zbynek Hrncir | CFX | 0 | October 2, 2001 07:30 |
