Home > Forums > Software User Forums > SU2
Surface Streamlines
Old   September 26, 2014, 05:24
Default Surface Streamlines
Zen
Zeno
Zen is on a distinguished road
How can I output the wall shear stresses to plot surface streamlines?
Thank you,
Zeno
Zen is offline   Reply With Quote
Old   October 11, 2014, 10:24
Zen
Zeno
To plot the surface streamlines with the data files su2 outputs you need to merge the surface_flow.dat file and the flow.dat file in one single .dat file.
For example, copy-paste the flow.dat file to the bottom of the surface_flow.dat file (in this way the flow zone is identified as zone number 2), and add the following lines just before the start of the surface data:
PARENTZONE= 2, %it identifies the zone number 2 (the flow zone) as the parent zone
AUXDATA Common.BoundaryCondition = "Wall"
AUXDATA Common.IsBoundaryZone = "TRUE"
If you then load this file into Tecplot, you'll be able to plot the surface streamlines on, for example, a wing.
Old   October 20, 2014, 15:03
hlk
Heather Kline
hlk is on a distinguished road
Thank you for posting the solution to this problem.
hlk is offline   Reply With Quote
Old   May 19, 2015, 12:45
Default VTK implementation
D L
DLuo is on a distinguished road
This looks like a Tecplot specific solution. If I remember correctly, Tecplot will allow you to use velocity vector in the first cell off of the surface to plot Shear Stresses.
I'm not positive Paraview has a similar feature. Is there a way to natively output Tau vector into the surface.vtk file?
DLuo is offline   Reply With Quote
Old   May 26, 2015, 17:32
hlk
Heather Kline
Thanks for your question.
The easiest way to do this will likely be to postprocess the surface_flow file: the momentum components (density*velocity, labeled CONSERVATIVE_2 - 4), the density (CONSERVATIVE_1), and the skin friction coefficient are included in the output, so you should be able to get the tau vector from those components.
Also, the components of momentum (conservative_2-4) may also help with this plotting problem directly.
Alternatively you can code this in yourself by editing output_paraview.cpp and adding the tau values to the Data array in output_structure.cpp - however that will be more complicated and if you are not careful may produce code which works for your case, but produces unexpected output in other cases.
output file, surface streamlines
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Surface streamlines on axial flow fans Jennifer CFX 2 February 17, 2009 15:50
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
