Home > Forums > Software User Forums > SU2
Are velocities in flow.vtk?
Old   September 23, 2014, 15:46
Default Are velocities in flow.vtk?
Chris L
Chris Lee is on a distinguished road
I got the SU2 code installed and running on my PC (Windows 7).
I have a flow solution, and an adjoint solution for the NACA0012 test case, after doing battle with unix/dos line termination issues in the .cfg files.
Two questions, if I may.
1. Do the velocities appear in the field/surface output file, or do I have to derive them? I am trying to use Paraview, and I want to look at velocity vectors (or streamlines), but the velocities don’t appear to be available from the flow.vtk file.
2. I am also wondering what the “Conservative1, 2, 3, 4” variables are.)
Thanks for any guidance!
Chris Lee is offline   Reply With Quote
Old   September 24, 2014, 05:29
Facundo
akun646 is on a distinguished road
Hi Chris,
these threads may help you....
http://www.cfd-online.com/Forums/su2...pretation.html
http://www.cfd-online.com/Forums/su2...ervative_.html
Cheers!
akun646 is offline   Reply With Quote
Old   September 24, 2014, 16:22
Default derive velocities from density & momentum
Chris L
Perfect.
Thanks, Akun646.
conservative1, paraview, velocity, vtk
Artificial high velocities at the interface using interFoam Arnoldinho OpenFOAM Running, Solving & CFD 38 October 31, 2024 09:00
Calculating vortex cores of relative velocities Dorit Tecplot 1 December 17, 2015 06:23
[OpenFOAM] converting velocities from cell centers to corner torsy87 ParaView 1 April 14, 2013 09:09
InterFoam Artificially High Velocities andersson.j OpenFOAM Running, Solving & CFD 0 February 8, 2011 11:43
Derived velocities from loss coefficients ?? jakjak CFX 1 December 20, 2007 15:38
